5mm spacers with standard wheel bolts?
anyone running 5mm spacers with standard bolts, always been abit dubious of spacers, can you get 5mm longer wheel bolts??
I *think* jason runs standard wheel bolts on a very low spacer. Might only be 3mm tho to clear his brakes
Matt
You can cut down a longer wheel bolt to whatever size you want. Personally on a 27mm wheel bolts I wouldn't risk a 5mm spacer especially as it won't be hub centric.
whats the lowest hubcentric ones you can get?
Always get longer wheel bolts!
you can get them from various wheel and tyre places off ebay. Normally just over £1 each or so.
Matt
I do, but if I had any doubts about the amount of "bite" the bolts are still getting, I would switch to longer ones, 3mm is roughly 2 turns less on a bolt which turns about 12 to 14 times normally. I have definitely had no issues of any kind and personally am happy using my standard bolts (I am using tapered ones though, if that makes a difference)
10 maybe, my 10mm spacers I turned down on a lathe from 15s.
