Octavia 1.9TDi MK1 Cutting out
Hi All,
I have had this fault since December during the really cold weather.
My car is the 90hp, AGR engine and has ran without fault for three years.
Symptoms:
Starts first time, every time - but has started cutting out or stuttering when driving and sitting on my drive. The engine dies for a second and the glow plug light flashes twice, recently during heavy rain it cut out three times on one journey home from work (17 miles). You have to turn the ignition off and restart while moving - starts first time.
Parts Replaced / Checked:
Relay's 109 and 103 have been replaced. Wiring around the ECU and relay plate has been inspected, battery and air box removed to check wiring up to the injection pump. ECU plug has been removed and cleaned, ECU has been removed and PCB inspected for dry joints by eye (I was thinking of taking it to work and using the Microscope)
I have the latest VAG-COM report below:
VAG-COM Version: Release 409.1-S
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01: Engine
Controller: 038 906 018 GM
Component: 1,9l R4 EDC 0000SG 2162
Coding: 00002
Shop #: WSC 31480
4 Faults Found:
01044 - Control Module Incorrectly Coded
09-10 - Adaptation Limit Surpassed - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-00 - -
16989 - Internal Control Module: ROM Error
P0605 - 35-00 - -
P0605 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes
Controller: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03304
Shop #: WSC 31480
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1U2 919 034 G
Component: A4-KOMBIINSTR. VDO V22
Coding: 02440
Shop #: WSC 20038
IMMO-IDENTNR: SKZ7Z0Y0439046
No fault code found.
Address 46: Central Conv.
Controller: 1J0 959 799 Q
Component: 5G Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
3 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
End --------------------------------------------------------------------------------------------------
I have cleared all the faults but the "00849 - S-contact at Ignition/Starter Switch (D) 25-00 - Unknown Switch Condition" which point blank refusess to go away.
Does anybody have any ideas?
Next stop will be the scrap yard :'(
Thanks for taking the time to read my guff!
Cheers, Mark.
