Pesky Coilover
Guys after puttung the wheels on i went round messing with the ride height :smirk: the front drivers is bloody nye on wedged :doh:
a turn was managed ... just :@ using lots of wd40 and some large grips as the spanner were trying to munch the lugs
its kw's so its the metel thread and poly platforms but i just cant get it doing anything so im guessing theres some crap in the thread :swear:
also does anyone have any ideas if a turn on the front is the same as a turn on the rear ?? :think:
Hi There I beleive it is.
I had same issue with turning. Did you unscrew the grub screw??? silly question as that grub screw gets filled with crud and you can't see it.
Also lots of road crud gets in the threads. I lowered mine before i raised them (or was it raised them before lowering) to clear the crud and they started turning ok. :thumbup:
yeah i had the grub screw out :giggle: it just didnt want to know :wall: when i try again maybe il jus try turning back and forth as much as pos :wonder: whcih wasnt much in the end damit AAAAAAAAAAAAAAAAAAARRRGH :@
