Retro-Fit Cruise Control
As a newbie I apologise if I'm asking something has already been covered.
I am trying to fit Cruise Control to my 2008 Octavia 2.0TDI 4x4. Have installed the stalk without problems, recoded the Steering Wheel Controller with VCDS, code accepted but, still no Cruise. Do I have to run a wire from the Steering Wheel Controller to the ECU ? or do I need to change the ECU coding? The ECU number is 03G 906 021 SS for the BMM engine.
Any help or guidance would be much appreciated, thanks
Pretty sure you have wire it in back to the fuse box I think, not 100% sure but I looked into retrofitting cruise into my VW Beetle and it was replace stalk, encode the ECU and run a cable, so if you havent run a cable then thats what needs doing B) Hope that helps.
James
Did you recode the engine ECU 01 on VDCS???,do that and it will work.
Trev
<br />Did you recode the engine ECU 01 on VDCS???,do that and it will work.<br /><br /><br />Trev<br />
<br /><br /><br />
U need to recode the engine option ---
In engine coding---- go to coding II and write the software coding11463
Thanks all for your input, all now sorted and working :yes:
so what did you do?
step by step and in plain english please-for us the bloody foreigners!! :'( -
Could you please post what you did..
