High Idle
Hi everyone my wifes 07 fabia vrs has lately been idling high when started ,
wether it be hot or cold , It seems to idle at about 1500 rpm .
If you tap the throttle pedal it tends to settle back to 1000 rpm .
Sometimes when you drive at a constant speed around town or something like that ,
when you come off the throttle it drops the revs to 1500 rpm
Sounds like something sticking or some thing ?
Any ideas .
Lee
Throttle pedal control module faulty (very common.) 1/2 hour labor part is about £90
throttle pedal fault needs new pedal
yes throttle position sensor needs replacing
