Vrs Battery Will Not Come Out Of The Tray?
Maybe a stupid question...
I tired to remove old battery this morning but it won't come out?
Is there a locking fixing/plate somewhere?
Can anyone point me out where is it located and how to get to it?
the car desperately need a new battery fitted for a long trip tomorrow!
If the arrangement is the same as a 2002 1.9 diesel estate then there is a clamp at the bottom of the battery box which locates on the lop at the bottom of the battery. It is tightened and released via a hexagon headed set screw on the outside of the battery box's front edge.
Hope this is of help.
Regards
G
Yeah, if you look down the front of the battery box you will see a hex bolt & fixing plate that needs releasing. However, you will need an socket set with an 12" extension to get to the bolt.
Many thanks this is helpful
I will have a look at it once at home tonight!
It's all done now with windows n clock reset many thanks
