Porsche Brembo's on Ebay
312's but dnt get thrm they are REAR brakes for a reason ( piston size too small to be used on the front)
these are the ones you need for front of fabia vrs...also need 312 discs/carriers adapters which are bout £90 and new brake lines.
Edited by warwick hunt
they are crap....
piston area is smaller than OEM 288mm setup...
yes they will increase initial bite as they are 4 pots, but hard braking they will fade as the pistons just aint sized for the front of a car...
if you want 4 pots, get the 323mm brembo's off a Leon Cupra R, also known as the brembo GT kit :thumbup:
Exactly what Big Jase has said, there rear brakes for a reason !!!
There are propper full brembo kits for just under £500 which is a bargain :thumbup:
Edited by R1chard
