starting a tdi conversion
**** up so now new post
OBD-data link connector 16pin.
Use 3 only, if yellow connected ignore it
Pin 4---Brown,-earth
Pin 7---Grey/White,-Pin 61 ECU
Pin 16--Red/White
(Pin 15--Yellow)
All this is found inside the car, plus brake pedal and clutch switches.
Pin data later.
Once you have stripped the loom you will see the groups of commons which link together at some point inside it.I used the Skoda glowplug system.If "or" point where my loom differed from wiring diagrams.
ECU PIN WIRE COLOUR
1 BROWN------------Connects to a body/engine earthing point, it
also joins browns from 24;46.
and the black from terminal 3,
crank sensor, and terminal 5
MAF sensor
2 BLACK/GREEN------Connects to dash control t5--
left off
3 Blank
4 BROWN/YELLOW-----To brown/yellow loom connection and then to t6
fuel pump connector
5 BROWN/YELLOW-----To brown/yellow loom connection and then to t6
fuel pump connector
6 Blank
7 GREY/GREEN-------Pump modulation sensor, t2 fuel pump connector
8 GREEN/YELLOW or
BLUE-------------Engine speed (crank) sensor t2
9 VIOLET/WHITE-----Dash control t26; left off
10 Blank
11 BLUE-------------Needle lift sensor (injector3)
12 GREY------------- " " "
13 BROWN/RED--------MAF sensor t6
14 BROWN/GREEN or Temperature sensor t3
BLUE/BROWN
15 WHITE/BLUE-------Throtle position sensor t1
16 Blank
17 WHITE/RED--------Clutch switch t2
18 Blank
19 RED/GREEN--------MAF t1
20 WHITE/YELLOW-----Brake pedal switch 2(blue)
21 Blank
22 Blank
23 BLACK/YELLOW-----Black/Yellow loom connection, then engine control relay t6 c as blue/red
24 BROWN------------Earth, connects to other browns
25 BROWN/WHITE------EGR t2: EGR t1 black/yellow fed via loom connection
26 Blank
27 Blank
28 Blank
29 VIOLET/BLACK-----Fuel quantity adjuster position sensor,pump c connector t1
30 Blank
31 Blank
32 Blank
33 BROWN/WHITE or BROWN/BLUE---Common return via loom connection for tps t6, pump t4
brake pedal pos.(2) t2, clutch switch t1,
intake air temp sensor t2, crank sensor t1,MAF t2,
temp switch t1
34 BLUE/GREY--------Cruise control. Left off
TBC
Edited by rolo
thanks for all your help, i managed to get it all in working! i didnt use brake sensor or speed sensor either, and too lashed up a bracket on end of cable for the tps!
my big problem is now that i trusted my mate to solder my chips into ecu (this really was my mate not me) and now its completely dead :doh:
what i need to know is can i just get another with same number 028 906 021 GG and plug it in and away to go, or do i need immobiliser and key etc. really annoyed about this, do you know anyone who can recode these?
please help
can i reprogram the ecu/immo with vagcom and my ebay odb lead or do i need the full software with genuine lead?
Tom may know that.I`d get another ecu and immo deleted. That chip will cause you clutch problems. I`d just do the variable resistor on the fuel quantity circuit, worked wonders on the toledo, estimate 10-15 bhp cost pennies.Adjustable from inside and turned on/off
Edited by rolo
Well, started so I`ll finish that which may be useful to others.
PIN 35 RED---------cruise control, left off
36 Blank
37 Blank
38 BLACK-------Ignition switched live
39 BROWN-------Earth, loom connector
or RED/WHITE---Alternator
40 Blank
41 Blank
42 BLACK/VIOLET-Engine control relay t5 (negative switched by ecu)
43 BLUE/WHITE--Dash control, left off
44 BLACK/RED----Brake pedal position switch 1 t2, bpps t1 fused batt live
45 BLACK/YELLOW-Common, loom connection, also to black t1 speed sensor
46 BROWN--------Earth
47 RED/BLUE or BROWN/BLUE--- turbo wastegate controller t2
48 BLUE/GREEN--Coolant heater, left off.
49 BROWN/YELLOW-Loom connection links pins 4,5,49,30 with pump connection 6
50 YELLOW/BLUE--Glow plug relay, left off.
51 BROWN/BLACK-- Becomes brown Fuel injection timing solenoid, pump con.t4
52 WHITE/GREEN-- Fuel quantity sensor, pump connector t3
c 53 WHITE/BLACK-- Fuel cut off connector.
54 Blank
55 GREY/RED-----TPS t3
56 Blank
57 YELLOW/GREEN-TPS t2
58 Blank
59 Blank
60 Blank
61 GREY/WHITE---OBD plug and immo
62 GREEN/WHITE--TPS t5
63 YELLOW/BLACK-- Fuel temp sensor, pump cntrol connector t7. When
shortening wires do not join this to BLACK/YELLOW
64 BLUE/YELLOW----Intake air temp sensor t1; t2 brown/white or
brown/blue return
65 GREY/BLUE------TPS, t4
66 BLACK/WHITE----cruise control, left off.
67 Blank
68 BLACK/YELLOW---Common live switched by control relay
Simples
Edited by rolo
a
Edited by rolo
thanks Rolo, the pin outs and colours are going to be useful for me. i pretty much at the moment got a bag full of wires under my bonnet which i had no idea what they did so just had to leave them there. Now i can do a proper job :thumbup:
thanks again for all your help during this project :thumbup:
Make sure that you solder and shrink wrap any joints in the loom, but just crimp any joints or terminals not in it.
have fun.
Edited by rolo
Yes, you don't reprogram the ecu per se, it's the immo unit you need to align with the ecu, the procedure is immo 25, adaption 10, channel 0 read then save.. Not having read this entire thread I don't know 100% what you are trying to do, but on the ref lump the immo unit is built into the fuel cut off solenoid, other tdi engines have a separate immo box and some have the same setup as the aef engine.. I'll read through this thread properly later on and get back to you
Edit; you can do it with the cheapo eBay cable but you need to have a registered version to access channel 0 in the adaption screen.
and the felicia temp gauge wires are 2 and 4 yellow and brown- these connect to the same on the golf switch.
you can use the passat water exit from the back (rhs) of the engine which has accomodation for 3 std type sensors and use one for temp control of glow using an earlier type vw sender and probably an earlier skoda for better gauge control.
yes. this is confusing me quite a bit. all i did was plug the wires from the felicia into the temp sender and felicia wires into the radiator. i have no readout on the dash. the engine doesnt really seem to get very hot either. im a bit confused about what you mean.
TDI runs much cooler.
Golf and felicia 4pins are different. The ecu needs the golf 1-3 connection. The dash needs a felicia 2-4 with the yellow and brown 2-4 felicia wiring
Played with the needle to get some sort of reading.
You need a skoda resistance sensor supplying the yellow wire, the brown is earth. My solution was (although never done) to use a one wire temp sender from say, a favorit and introduce it to hot water via a passat rhs hose connector as it has a suitable position.
There are 3 sensor positions on it and I would have run a caddy/t25 glow plug control, 1 wire, sensor to the felicia red wire.
It seems you have no temp control other than IAT to the golf ecu at present. ECU pin 14 should have this connection with a return to pin 33
Hope this helps abit
Oh, and if you`re shortening the wires to make it all tidy,the crank sensor and needle lift are shielded against EMR so used aluminium tape to try and reproduce this over the join
Edited by rolo
  • 5 weeks later...
cheers rolo. I'll be honest with you, most of that went over my head but i've been running now fine for ages, so am going to leave it alone until i drop it into something a bit better i want a fun really but its finding one...
Just doing the 16v thing and noticed the afh head has a water pipe with 2, 4 pin points, if this fits, to be tried later, it would solve the temp gauge problem as the tdi and na senders could both be used, golf to ecu and felly to gauge; 1-3 and 2-4 respectively.
Edited by rolo
sounds promising :thumbup:
i could do with knowing what temp it is if i ever get stuck in traffic, because i'm not sure even my fan cuts in
won`t work will look out for another.
Right think sussed it.
The passat afn cylinder head water pipe I mentioned earlier fits the 1z. The bit I couldn`t see in the shed was that there`s a blank on the other side that takes a 4 pin sensor. Put the felicia one in it with the felicia wiring.
The one on the front of the engine is the golf, connect that to the ecu wiring. You should get a working temp gauge, temp control on the glow plugs and coolant temp fed into the engine managemnt.
I'm a bit disappointed that there is no pictures in this thread to show the build. :doh:
After all, the subject of tdi conversions does crop up quite regular on briskoda, it would be nice if there were some sort of guide or pictorial.
Gave up trying to post pics 3 years ago and lots of tech stuff. Too much to learn when teaching yourself and over 60, just keeping up with what I`m interested in and that has changed immensely in the last few years. I come across switches, now, that have 3 wires and seven functions.
Although never was my build thread did take some images that I can email to someone if they want to post them.
To be honest a tdi felly conversion is fairly easy. Start with a diesel replace the head, pistons and rods.
Choose a injection system and then either make up a loom and use tdi pump and bracket or fit a 10mm or bigger Bosch pump (on the aef bracket if landrover). Cut a hole in the bonnet so it shuts or modify the inlet and make up a downpipe.
Hopefully the OP has images.
  • 2 months later...
Just been to Brickwerks for some t3 stuff and find Simon sells a plastic T pipe that reconnects a water pipe and takes a vw temp gauge. Solves the fitting 2 temp sensors problem. Around £10.
  • 8 years later...
What engine mounts did you use for this, a friend has a Felicia we were trying to fit a 1z but the engine seems 2 far forward alternator hits the rad and it still needs to go another 1-2" to get the dog bone mount on, original Felicia gearbox used also and currently the original engine mounts both on block and engine to body
