engine trasplant help
i have taken a 20v engine and put it into a t4van.van runs but like sh.t
we need to plug vagcom in but have no diagnostic port.i have the plug
but no wires.need help to wire it in so it works any help would be good
what loom you running?
standard ecu,the imobilsier removed and mapped by jabber sport
what about exhaust wise you running 2 lambda probes? so your running 1.8t&loom? standard dash? could be something not plugged in as simple as, need to see any fault codes really, could be many things
thats the problem dont know how to wire the obd port in,if that is done we can see why it runs like poo
why are there no wires for it, it been cut off or something,
yep you got it cos that would be simple ,just got the plug from vw.now i need to wire it in
the loom must still be there somewhere you might have to dig abit to find it, then your just need someone to post up a pic of the back of there plug so you can wire it up
found the problem.found that 1 the injector seals were naf and that the fuel rail and the injector rail
were round the wrong way.oh the joys of a second hand engine
Sounds like someone had fun with your engine before you got your hands on it! :giggle:
yes mate,but we sust it out in the end
