Occy VRS brake upgrade!
Do your fluid as well, if you can. The 2500's will run hotter than the standard pads.
Budget end of the market, but decent all the same, Castrol RS Super DOT4.1,
Oh & Bill, did youget your brake fluid cooling sorted?
am i right in thinking the vrs has a twin ciruit system? no bother if it is.if not whats the bleeding sequence on it?or is it pressure bleed with vag-com/1551
bumpety?????
I can't remember tha answer. Suggest you PM Ross Clarke or Big K. They willknow the answer.
IIRC, we just bled mine as per a normal car. Dealers I think use a special tool if that is any help what so ever.
No ones mentioned DS3000 squeeling more than the bloke out of The Omen. ;):D
I thoughtit was the bloke in Deliverance :D
