DRL and Cornering fogs Pre FL?
yes
Will give it a go in a minute :-)
Need to look into sourcing a high end CEM so I can get cornering fogs now ....
Let us know how you get on Andy, some pics would be nice too if you get a chance :notme:
Well, it worked. I have front fogs as DRLs when the handbrake is off at 70% brightness. The fogs are at 100% when you turn them on manually.
I will get some piccies tomorrow if it isn't raining :-)
I have a new CCM to fit as the MAX one I have in at the mo is about 98% compatible :-(
I have done this on mine also but with Scandanavian DRL's and fogs instead of headlights. I mainly did it that way as I wanted the front sidelights on and some lighting on the back as well. I've turned the drl fogs down to 50% to try and look a little less Chavy (running fogs all the time alla corsa brigade), I realise this might shorten bulb life a bit but hey ho. I have also considered turning them down to 0% and just having sidelights but haven't made my mind up on that yet.
I know what you mean about the Corsa brigade, but the absence of sidelights and rear lights makes them look more like DRL's. I might yet turn them down to 50 or 60%, need to see what they look like on an average day - it was pretty overcast today so difficult to tell.
Only one tick in VCDS to turn them off come MoT time :-)
