Soft coding on Fabia airbag module?
My mechanic friend is trying to fit a replacement airbag module into a 2002 Fabia. Apparently the new module will not talk to the system, and will also not accept the soft coding from the old module.
Anyone know the usual protocol with installing a replacement airbag module? It is the same part number too.
Hope the following helps, but it's not 100% clear, as it's copied from a PDF file. It also refers to Skoda Diag kit and not VAGCOM.
Coding airbag control unit
Coding is necessary if a new airbag control unit is used.
Conditions:
• Warning lamp for airbag -K75- flashes continuously.
• Airbag control unit -J234- was replaced.
Readout on display:
– Enter function 07.
Readout on display:
– Confirm the entry with key .
Readout on display:
– Enter code number in accordance with the table and
confirm with .
Vehicle system test →
→ The fault memory is erased
Note
Caution! →
Fault memory was not interrogated
Vehicle system test
Select function XX
Vehicle system test Q
06 End output
Q
Vehicle system test HELP
Enter address word XX
Note
Select function XX
Coding control unit
Q
Coding control unit
Enter code number XXXXX (0-32767)
Q
Vehicle equipment Parts No. Control unit code
number
Driver airbag
belt tensioner (electrically ignited)
side airbags
6Q0 909 605 H 011) 12337
6Q0 909 605 H 072) 12343
1C0 909 605 H 073) 12343
1C0 909 605 K 044) 12340
FABIA 2000 􀂳 Body Work
Edition 01.05 Self-diagnosis for Airbag System I
S00.5319.15.20
01-5 page 9
01
– If the following message is displayed, the coding is
done:
The control unit identification number, the control unit
code number and the workshop code are displayed.
– Press key.
Readout on display:
– Ending output ⇒ 01-5 page 8.
– If the following message is displayed after entering the
code number, the coding is incorrect:
In this case the control unit was not coded with the data
required for the vehicle. Check whether the right control
unit was fitted on the vehicle (compare part number and
Driver and front passenger airbag
side airbags
6Q0 909 605 H 021) 12338
6Q0 909 605 H 082) 12344
1C0 909 605 H 083) 12344
1C0 909 605 K 054) 12341
Driver airbag
6Q0 909 605 H 031) 12339
6Q0 909 605 H 092) 12345
1C0 909 605 H 093) 12345
1C0 909 605 K 064) 12342
6Q0 909 605 H 041) 12340
6Q0 909 605 H 0A2) 12353
1C0 909 605 H 0A3) 12353
1C0 909 605 K 074) 12343
Driver airbag
belt tensioner (mechanically ignited)
6Q0 909 601 C 012) 12337
1C0 909 601 C 013) 12337
1C0 909 601 A 0T4) 12372
6Q0 909 601 C 022) 12338
1C0 909 601 C 023) 12338
1C0 909 601 A 114) 12593
switch for front passenger airbags
1C0 909 601 A 0S4) 12371
side airbags
1C0 909 605 K 014) 12337
1C0 909 605 K 024) 12338
1) Valid for vehicles 􀂳 11.00
2) Valid for vehicles 12.00 􀂳 02.01
3) Valid for vehicles 03.01 􀂳 07.02
4) Valid for vehicles 08.02 􀂳
number
6Q0909605 H 02 AIRBAG VW5 0003 →
Coding 12338 WSC XXXXX
Select function XX
Fault →
