loss of water
just bought the car and found that every 2 days have to fill the water tank up, its a leak is on the front drivers side.
which side is the water pump on. Cant see when the car is stood , after ive been on a run then look under the car, belly pan wet plus water dripping. Any one got any ideas.
Radiator leaks are pretty common. Look for white stains left by a leak.
Yes, Our radiator started to leak at 51,000 miles. Our independent repairer fitted a new one for £257.00. Got the money refunded less £100 excess from Warrantywise. (eventually) see my thread WarrantyWise.
Jenks
Could be the mechanical in the Water Pump.
Horse.
Check the hose to the coolant sensor, rear drivers side, little green unit, cover off, torch to see down the back where the exhaust runs away to.
Remove engine under-tray for a better closer inspection.??
Could be worse, you could have extra water in the passenger footwell.
