New VCDS Owner
OK so my VCDS HEX+CAN should be arriving tomorrow. So far I'm planning to...
Do a full scan and save all the coding for when I get something wrong - I assume you can do this?
Try and make my speedo more accurate.
Try and make the trip computer MPG more accurate.
Play with the performance measurement tools.
What else will I be able to do?
Cornering fogs can't be enabled on a 2006 Octavia can they?
Also, my housemate has a 2001 Audi S6, what kinda stuff will I be able to do on this? I assume not as much with it being an older CAN system?
Edited by blank
You can run and save the complete Auto-Scan prior to any coding modifications as shown here:
http://www.ross-tech.com/vcds/tour/autoscan.html
I would personally save a backup of the scan in another location for a backup, emailing it to yourself or coping to a flash drive would be sufficient.
Depending on the installed module, fogs as cornering lights should be possible:
http://octavia-vrs.com/cms/content/enabling-cornering-light-function
http://www.ross-tech.com/vag-com/cars/Golf5.html
The 2001 Audi S6 will be limited due to the age and (lack of) diagnostic capability. You should be able to tweak the windows via remote and a few other minor modifications to that car:
http://www.audiworld.com/tech/elec36.shtml
