Cruise Control
Cruise not working! Any known fault / cause.
Had same problem on my A4 & found it to be the clutch switch. Sorted f.o.c. except few quid for reset :thumbup: .
Is there likely to be some similar cause / solution with a dsg? I have looked under pedal but cannot see anything resembling switch. Maybe not looking in right place??? Shed any light please!
Do you use the on/off switch on the indicator stalk to turn the cruise on and off ?
These switches are known to fail / contacts get dirty, so the switch fails to work, so this could be causing your problems.
I'm pretty sure someone posted a guide on how to clean this switch.
I'd heard about it, so tend not to use the switch and just cancel it using the brake/clutch pedal.
Only just got the car last sat so there is option to go back to garage. hastle though & time. Can you point me to the guide, and do you know if there is still a pedal switch of some kind? Logic would say yes imo. Cheers.
doesnt help... ive tried that aswell and it still gets dirty :-( every time i take it out and clean it, and it then works again up to 6-12 months
a couple of weeks ago it did it again. This time i was sitting in car waiting, and i took it out and blew into it with my mouth and it worked again after that. and now its doing it again. so that lasted around 14 days :-D good to know if your on vacation and it happens and you dont have electronic cleaning with you :-P
the guide is here in danish, but i remember that there was one in here who then translated it to english
The one I've seen previously was that Danish link, put through Google Translate:
http://tinyurl.com/6j8pqze
If you've cleaned it before, did you use anything like IPA to clean the contacts?
Here's the English version - saved from months ago!
You're not in the doghouse with me. Cheers pal. :thumbup:
Same one as in that translated link I posted, but in helpful PDF format - for you to take away and treasure forever :D
