Is this normal ?
Hi
I have a 170 4x4 model of the Yeti which i love and i have only just done 300 miles. However i have noticed that when changing gear , the clutch pedal is vibrating . I have never come across this in any previous car i have owned and i just wondered if this was normal in this car ? I think i can also hear a small noise coming from under the front of the car at the same time as changing gear , but this does not happen all the time , just the vibrating clutch mainly.
You opinions appreciated .
Gordon
Mine does this as well. Only when a gear is engaged and not in neutral. Not aware of any noise when changing gear.
Andy
Same here - just thought I had sensitive feet :)
Hi
Yes it does only occur when changing gear , wonder if this is normal though.
  • 7 months later...
Hi
Gordon
the same problem. at 24000 km they replaced the clutch-set and the dual-mass flywheel, but it was not a solution. what about with your car?
tibor
