Cold Air From Under Glovebox?
Hi, went for a spin tonight and had the heat on, but notice a cold draft coming from somewhere.
Under the Glovebox is blowing out cold air, while the vents and windscreen heater is blowing warm air?
Anyone know why this is happening??
Thanks Stevie
The only think I can think of is it's coming from the pollen Filter. However I think air is sucked in through there not blown.
Yeah, the higher the Heat Setting (1,2,3,4) the more cold air blows out.
Pollen filter missing, or cover not clipped into place correctly.
K Guys, i'll get a look tomorrow.
Going Garage to get new Tie Rod Ends put on.
+1 I've had this. :yes:
So pollen Filter missing?
or the cover? lol
didnt get round to looking at it today
Cover was missing on mine and I had the same symptoms, check it as soon as you can as it is a cheap part too!
Hi, sorry to bring this up again, but does anyone have a pic of where the cover goes or what the cover looks like?
-noob stevie :p
I wonder if I have this problem,
can u hear ouside noise when driving at speed from behind the dash?
-noob stevie :p
This thread will help.
Where is your interior Fabia air filter....
:thumbup:
Hi, no it when i have heat on a high setting it sounds like theres a fan in my glovebox lol.
But that could be similiar?
Just put your hand under the glovebox with the heat setting to high if you feel cold air blowing, then its probably the same as my problem.
Hi Thanks i think thats the Cold air thingy on the right isn't it?
I've had a look but just needed to make sure, anyone got a part number?
