wiring in my DV Cam
Hi all, I need to piggy back off the fuse board to get 5v to the rear view mirror. I think I know what I need:
12 socket
mini blade fuse piggy back
inline fuse holder and 1amp fuse
I plan in using the cigar cable that it came with. Any suggestions on which fuse to use? Is it "mini blade" size? Any suggestions where to get the bits??
Thanks all. :thumbup:
James another approach you could take, since it's for such small power, is to drill through the plastic and leg of a fuse on one side, you could solder a wire pushed through the hole. This gives a neat, fused, easily removable, plug in connection to power. Keeps parts costs right down too.
