my felicia needs ur helps right now plz
hi everybody ,i have felicia 1.6 mpi 1997 , i had about 5 days ago the centeral lock not work and i siad i will do it when i will have time , and i moved today from city to onther city about 400 k m , in my way i felt voice from the right side and the headlight start cuting and stop and working and stop and working again with this strange voice , i was driving and i close the head light to not have problem and i understanding when the headlights stoped the heater stoped with too and after some kilos i pushed the cleaner and it not working too, after some time i under stand when i take my leg out gas this is working and when i push my leg on gas this is stop , and when i arrived and i stoped car and i cheked the belt`s generatour , and fueses all is normal and i try to start car , and the car not started ,and i have new battery , im not understand what is it ?
hope u will understanding me because my english not well
thanks
thanks
could this be a bad earth somewhere ? (im im reading it right)
no, sounds more like bad english to me!!:giggle:
i think you have a loose earth connection on the battery or car body somewhere
give it a rest mate, this aint the spelling police website, if you want to flame people about spelling go into the fabia 1 section and poke fun at all the chavs on there... besides i bet your russian is good too right?
Yeah, I'd say earth (negative) connections were the ones to check.
As for the English, I'm anal about that sort of stuff, but having spent some time attempting to write Russian, the OP has my respect, for sure!
It sounds like maybe the yellow wire to the starter motor has broken, its the small one with a spade terminal on it, the car uses this to earth the main relay once the car has started. try removing the terminal and checking for breaks in the wire.
I hope I'm wrong and it's just a bad earth connection. The other possibility is fusebox corrosion. Ignore this until you've checked the earthing as above, and even then if you don't have a leaky front windscreen.
:) Check all the above and also make sure the alternator isn't overcharging...the voltage regulator can cause it to overcharge and damage control units and blow bulbs and fuses...it's a fairly common fault on Favorit's and Felicia's.
thnx for everyone who gave answer , and who care about my english i wanna say u have to take rest and dont answer me again because its the words is free and i can say to u more but i respect this site and all this ppl , really thanks guys and tomorrow i will check all what u said .
