chavy blue lights
Just noticed,my new fabia comes standard with chavy blue phillips type sidelights,funny never noticed these before are they only on the curve projector upgrade lights or standard in the fabia setup?
Bet the bulbs are brighter than mine, I've got a set of LED sidelights to go in mine soon.
Davy
They certainly are not standard in my wife's new Fabia SE. I'd get them swapped asap, before someone buys you a Burberry cap :lol:
Innit!! Brrrrrapppp Brrrrrapppp!! :D
Isn't the blue tinge designed to create whiter light?
Not chavvy to be honest, a lot of standard bulbs have the blue tinge on them I think.
I don't see them as chavvy, especially when turned on. Aston Martin use them as a standard fitment in their cars.
bangin'n innit ,potato :thumbup:
Davy
Hi I have changed the bulbs in the other fabia changed them with nightbreakers much better,I will change the elegance soon,how can you use LED'S as I thought you could'nt
+1
If you have DRL these don't work :no:
There fitted in the new Fabia MkII Vrs but there not wired up
sorry what dont work the LEDS sidelights thought you need a can bus or something
The new Fabia Vrs has day running lights fitted as standard, where the fog lights should be. When you turn your headlights on the Day running lights dim to become side lights. With the head light unit being standard across the new Fabia Range the side light bulbs are in place but do not work. In effect they are there for cosmetic purposes only
My sidelight work,I have the elegance with drls in fogs so what you are saying that the vrs sidelights are cosmetic but mine work for definate :wonder:
Don't think yours work if you have DRL,s. Turn on your lights and have a look. The Vrs has no fog lights.
Yes they WILL work on the Elegance...They DONT on the vRS...Due to the completely different design and set up
Chavy?....No they dont look it when on..They are whiter than standard 501 sidelight bulbs
Oooopppppss.....YES the do work ( that's what I meant to say)
Thanks Chris
Yes this is exactly what the blue coating does :thumbup:
They are also fitted to Superb's as well.
