Can't get my fabia low enough
I have spax rsx's fitted to my fabia and they are wound all the way down, but the rear is still too high for the wheels I'm running. Any ideas how to get any lower?
I have already taken out the top bit of the height adjuster
How much do the spax state they should lower?
Would imagine most coilovers should lower enough unless you want to go stupidly low
Take out bottom adjuster but i wouldnt personally :/
What wheels/ tyres you running on the rear. ?
What height have you got, what height you looking for. ?
Okay, the spax website etc quote a 65mm lowering height.
I'm running 16x8 rears with a 195/45 tyre.
And it does need to be 'silly' low
Take all the adjust cup out if you want it real low.
Matt
A pic would help :)
D90's by any chance?
I'm running Spax RSX also, still got the adjusters in, not silly low but can go quite a bit lower up front, max down at the back.
Edited by Tech1e
