Maxidot: Retrofit and FL VRS
Also looking to get this done. Can't seem to find any clusters on the net though. Shark is 15 mins down the road but if they don't do it anymore that's a bummer. But I work in Kings Lynn so wouldn't be too far to Yarmouth :)
Sent from my iPad using Tapatalk HD
No Shark don't do it.
I got my Pre-FL maxidot for £50 on ebay so keep looking!
Phil
Ok , 57 reg PD Vrs estate , what part no of clocks do I need ?
I'm after a FL one. Seem to be like rocking horse crap!
Plenty on Fleabay at varying prices but which one is the correct one ?
Can't see any mk2 FL VRS ones for TDI, unless I'm searching for the wrong thing?
For a pre-fl PD vrs any pre-fl from any PD diesel car. So doesn't even need to be vrs as long as its from a PD engine car.
  • 9 months later...
My 2011 2.0 Octavia (engine code CFHC) has an instrument cluster that seems to have some faults- indicator light at half brightness when headlights are on, but goes out if you open the door. If the fog lights are also turned on it goes out and the power steering one comes on. I'd like to take the opportunity to upgrade to maxidot.
The cluster fitted is;
1Z0920903M
combi-instrument; CAYC; BJB,BXE; AZV,BKD; CLCA,CLCB; CFHF,CFHC; PR-9Q2
 I have a brand new cluster;
1Z0920943D
combi-instrument; display unit for maxi-check; package; BJB,BXE,BLS; AZV,BKD,BMM; CHWA; CAYC; PR-U4B+9Q2
 Can this be fitted?
One for Eddie-NL  if so is it possible for these to be coded for the immobiliser off the car- ie sent in the post to you?
Edited by Tinbum
  • 2 years later...
1Z0920903M
1Z0920943D
 Can this be fitted?
Would like to know this too,having trouble getting someone to code it here (in n Ireland) can the the two clusters be sent to someone to code ?
Or is that not possible ?
that is possible
2 hours ago, Eddie-NL said:
that is possible
Brilliant I'll be in touch when they arrive @Eddie-NL :thumbup:
He did a brilliant job with mine.
