ABS Controller missing
3.5 year old 2007 2.0 TDi Elegance estate. NOT ESP
Used it Thursday no problems at all. Next day I go to take it out and and it lit up the Christmas lights and beeped. I checked with genuine Vag-Com and found that there was no communication with ABS controller. The result is, as one would expect, it throws up errors on other controllers.
The ABS unit is a TEVES MK70. - non ESP controller.
I drove it round the block a few times after clearing the codes to get a better idea on what's happening. I get some very odd effects which makes me wonder if there is more to this than just the ABS controller. I switch on the ignition and get "Emissions Workshop" on the Maxidot. The steering appears to have lost assistance.
Somehow on Saturday I was able to clear the codes and then everything was fine. I drove an 8 mile return trip which included parking thus stopping the engine. It behaved perfectly. Sunday - back to square 1.
This is the log from this morning. I've removed those controllers with no codes.
Monday,14,March,2011,09:02:52:30280
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 76
VIN: TMBGE21Z682014610 Mileage: 34270km/21294miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LD HW: 03G 906 021 LD
Component: R4 2,0L EDC G000AG 9184
Revision: --H07--- Serial number: SKZ7Z0G4306375
Coding: 0000078
Shop #: WSC 73430 790 00000
VCID: 6CF1F6B2360D
1 Fault Found:
005705 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 34270 km
Time Indication: 0
Date: 2000.00.00
Time: 02:41:20
Freeze Frame:
RPM: 0 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 11101000
Torque: 0.0 Nm
Bin. Bits: 00000000
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 044 F HW: 02E 927 770 AE
Component: GSG DSG 081 1402
Revision: 04608010 Serial number: 00000704261269
Coding: 0000020
VCID: 1819FA625215
1 Fault Found:
18259 - Powertrain Data Bus: Missing Message from ABS Controller
P1851 - 000 - -
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 34270 km
Time Indication: 0
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R
Component: ClimatronicPQ35 110 0402
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 45A763167527
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 E HW: 1Z0 920 942 E
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612037 Serial number: SKZ7Z0G4306375
Coding: 0000001
Shop #: WSC 25083 576 90994
VCID: 3A5D00EA0CD9
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 1
Mileage: 34270 km
Time Indication: 0
Date: 2000.00.00
Time: 02:37:36
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 010607F1001414
Coding: ED807F4E0002022303
VCID: 304922C2DAA5
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 34270 km
Time Indication: 0
Date: 2000.00.00
Time: 02:37:38
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A085283005B3F04850540085F96907CA0
Shop #: WSC 25065 210 90994
VCID: 83233D0EBB93
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 25065
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 34270 km
Time Indication: 0
Date: 2000.00.00
Time: 18:20:37
End ---------------------------------------------------------------------
Any advice much appreciated.
Not sure if it helps, but chassis type listed on above scan is 1K which is Golf/Jetta?? Octavia II should be 1Z?
Thanks for the reply.
It was def scanned as a 1Z. I note that all my previous scans state 1K0. I guess that 1K0 may be a generic term as the Octavia is a 1K variant, i.e. it is a form of the Golf platform.
Put the battery on charge and see if that improves things.
Modern cars are both heavy on batteries and also sensitive to a weakness in the battery.
