Tyre pressure warning light
Hi all,
Has anyone ever had there tyre pressure warning light come on for no reason?
I had just traveled approx 400 motorway miles when it came on, I pulled over at my first opertuinity and checked the tyre pressures. They were all as they should be (id checked them the night before).
Anyone have any ideas?
Hi wat pressure setting have u in ur tyres ? There's a tyre set button on ur gear stick press on that to set ur new pressure hold it down till u hear a bong
I did pup the tyres up to what it suggests on the inside of the fuel flap for 4 people plus luggage the night befre and forgot to reset it.
However I would have expected it to complain a lot sooner into my trip that it did if that was the problem.
When the warning light has come on & you have checked/adjusted your tyre pressures how do you get rid of the warning light please.
Any help appreciated,(Elegance combi)
Once pressures are correct; Press and hold the tyre set button when the car is stationary.
If the warning light cones back on then I guess there is a problem- either with tyres or sensors?
Edited by booski
JohnKsouth Many thanks, button pressed, light gone & I am off to buy a new set of glasses!
Thank youquote name=booski' timestamp='1301377898' post='2335661]
  • 5 years later...
hi all
sorry to open a thread again but having these problems.. when plugged into vcds it comes up trailer and tire pressure unreachable?
any ideas?
could it be the CAN or is there another box that could be faulty?
hi all
any ideas?
Rather than triple posting across two different model forums, it's probably best to start a new thread with an autoscan from VCDS.
I Dont get many answers on posts there. So stuck to the threads that people have commented helpful answers. Admins prefer you dont start new threads without going through existing
Thanks for the great help though.
If it's the same problem and recent it's worth using the same thread. In this instance it's a 5 year old thread and none of the participants have been online for over 2 years. The only issue here was not reading the manual, I assume you've tried 'the fix' mentioned of pressing the button with zero success?
On to the problem that you do have.
Without seeing what modules are installed and how they are configured it's hard to offer advice. You haven't even given a decent description of the problem... To confirm, the TPMS light is on and when scanned you've got two unreachable modules?
From where you've posted, you either have a MK2 Octavia or MK2 Superb, probably a pre-FL MK2 Octavia looking at your profile. As you list 170bhp that suggests a vRS yet in a previous autoscan you've posted it's a BKD which is a 140bhp engine. Is this the same car you're asking about in this thread: http://www.briskoda.net/forums/topic/378797-coding-for-a-replacement-comfort-control-unit-help/
In that car, it's probably indirect TPMS which is normally done by the ABS module - do you still have the wheel sensor faults? If so that could explain the TPMS light being on.
Is it a factory fit, aftermarket or bypass style trailer module?
In this thread http://www.briskoda.net/forums/topic/373827-lock-problem-following-vcds/ you post a scan for what I assume is the same car in a much better state. Notice there is no mention of a separate TPMS or trailer module fitted suggesting a bypass style unit.
Am I even close to being right with these assumptions? If so:
- Check it's a bypass trailer module by physically locating it and finding a part number
- Get the installation list fixed by removing module 65 and 69
- Clear any fault codes and post a new scan
At that point we might have a chance of actually helping :)
never judge a book by its cover!
thanks for the reply! yes it is the bkd 140bhp 2.0 octavia. mapped.
print out is below.
the wheel sensor faults were gone.
Check it's a bypass trailer module by physically locating it and finding a part number (found in boot) worked with no codes until lately)
- Get the installation list fixed by removing module 65 and 69 (removed in can bus module but light still on dash)
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBBE21Z662189611
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 HF    HW: 028 101 229 2
   Component: R4 2,0L EDC G000SG  7000
   Revision: 12345678    Serial number: SKZ7Z0E3273012
   Coding: 0000072
   Shop #: WSC 01286 386 08256
   VCID: 6ED9A54D7972D1518D7-803B
No fault code found.
Readiness: 0 0 0 1 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0000641
   Shop #: WSC 73430 790 00000
   VCID: 3F8728096E9868D9561-806A
1 Fault Found:
02214 - Tire Pressure Warning
            000 -  -
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3D7B520164947AC944D-8068
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003669815
   Coding: E18A8F030004140000110D000000000000087F075C
   Shop #: WSC 25055 576 16903
   VCID: 2B5F6C598AE0E479EA9-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 25055
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 25055
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 33
                    Mileage: 71901 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: Q4 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD02MV3I
   Coding: 0020788
   VCID: 3B7F5C197A8074F97A9-806E
   Subsystem 1 - Serial number: 6332MSME0C7A1570D
   Subsystem 2 - Serial number: 6342MSME0D02484EH
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0002042
   VCID: 77F78029062890995E1-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 941 D
   Component: KOMBIINSTRUMENT VD1 0918
   Coding: 0006401
   Shop #: WSC 25063 576 94681
   VCID: 387543154BB65FE197B-806D
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A27881A
   Coding: 3D3F0740071303
   Shop #: WSC 73430 790 12345
   VCID: 2A51695D851AFD7111F-807F
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 0918
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000758
   VCID: 36694D2D41A2A991857-8063
1 Fault Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
            012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00028 028 00001
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 18D002007F2D8505485F865004CC
   VCID: 79F38611303C86E9285-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000758
   VCID: 3777402946A850999E1-8062
1 Fault Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       013 0026
   Revision: 00013000    Serial number: SKZ7Z3E0050963
   Coding: 0000422
   VCID: 2D5B6241B4F4EA49F4D-8078
1 Fault Found:
00859 - Line-Output; Front Right
            011 - Open Circuit - Intermittent
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 3261713DADCAB5B1A9F-8067
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 336F743952D0BCB9A29-8066
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 C    HW: 1Z0 919 283 C
   Component: Parkhilfe 8-Kan H04 0020
   Coding: 0000001
   VCID: 3E79550D699261D15D7-806B
End-------------------------(Elapsed Time: 01:42)--------------------------
thank you for your help sorry if i seemed abrupt earlier!
Did you get a part number or anything from the trailer module? Do the lights work if a trailer is connected?
On that autoscan, there is zero communication with a trailer module although at least one module looks like it's been coded to think it should be there:
- If it's an OEM or similar module, then there is a problem with either power, ground, CAN or the module itself.
- If it's a bypass module, then the car needs coding to stop it trying to communicate with it.
As for '02214 - Tire Pressure Warning', that suggest the system just needs resetting as per these instructions: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK70)#Tire_Pressure_Monitoring_System_Reset
Have you tried them?
No worries. It's just much easier if the information is included in the first post as it saves trawling around the forum trying to find it.
As this is now a thread in the Superb section it's going to be harder for future Octavia owners to find it which is why it's a good idea to start new threads, they can be merged or moved if needed ;)
need to check if lights are working when plugged in! will check in daylight
part numbers:
pct automotive
zr2000
17161hvle
as for the tyre pressure issue problem sorted thanks lad
good point it might be able to get moved!
many thanks again!
Excellent!
The zr2000 is a bypass style module so the car shouldn't be aware it's there. We need to code out the towing module to get rid of those errors.
Basically check each section of this guide and do the opposite http://wiki.ross-tech.com/wiki/index.php/Trailer_Hitch_Retrofitting_(1K) :)
