Removing Wax with IPA
Hey guys,
I've noticed a lot of the professional detailers mentioning they use IPA to remove old wax from cars.
I am guessing they are referring to Isopropyl Alcohol?
The thing is I have been looking for a decent degreaser for the car, and I always have this stuff knocking about, I use it for all-sorts!
So, is it safe to use?
Cheers.
Stu.
Hey guys,
Cheers.
Stu.
I would guess you mean detailers using an IPA wipedown after polishing where it's used to remove polishing oils but could indeed be used to remove waxes I guess, a good clean cloth would be required and it would need to be cut with water but what application would you use it for?
I want to remove old wax before claying, applying Poorboys Black Hole and then a new layer of wax.
I've been told washing up liquid does quite a good job too?
Edited by Stu vRS
Claying will remove it anyway Stu?
Ah right, I was led to believe this only removed some of the wax and not all of it.
i recently had issues with my wax, looked like it had runs in it(weird). removing it proved to be a nightmare, tried alchol wipes, clay bar, swissvax paint cleaner etc etc etc. i ended up needing to use a light cut polish, paint cleaner then a paint prep wipe......the joys :)
Bilt Hamber Clay and some washing up liquid and hot water = no wax!! :thumbup:
