Radio/CD info display
I have a mk 1 Superb 2003 Tdi 130bhp pd . The Audio display has gone out I am therefore unable to alter volume/CD track etc from the steering wheel. Could this a software problem or a simple elctrical fault, any ideas?
Thanks John W
Edited by Tiffy
Thanks John W
Is it the standard head unit or an aftermarket one? If its the standard probably a loose connection. If its an aftermarket you may need an adapter but they're not available for all models of head unit.
Thanks, this unit has been in since new, hoping for a loose connection!
John W
Thanks John W
hi there
if the radio is standard and fitted ok ,it could be a fault, but, don't rule out water ingress
what other systems arnt working?
check obvious puddle lights, all courtesy lights, boot light, central locking, exterior door mirror, lights inner handle lights
these all went bandit on mine and i had to do the wiring mods and pollen housing seals
  • 8 months later...
Thanks John W
This has started on my 54 reg superb too.
Have you solved the fault?
