MIL Light ON : DTC P1178
Hi there.
Yesterday the MIL light turned on . Vag com reports the error code 17586 - DTC P1178
Linear 02 Sensor / Pump Current Open Circuit
Could it be caused by a loose wire some where? What should i check?
Any suggestion?
I've got a LPG system on my car, so as far as i know a couple of lambda (is it the linear 02 sensor?!?) wires are connected to the LPG control unit.
The error code is intermittent. After 10 or 15 km the MIL light turned off. This afternoon turned on again.
Give you LPG fitter a ring as it could be a common problem ?
