Winter wheels
I've been offered some s/h Audi A4 wheels from a friend. They will be cheap so I thought about using them for some winter tyres.
They are 7J 16" but ET 42 not ET 45.
Will this 3mm make a difference?
Will it give me more or less clearance to the strut (I'm having difficulty getting my mind around this)?
tom
They will fit fine :thumbup:
They'll give you more clearance i.e. further 'outboard'.
Hi Tom,
yes you should be OK with those rims, going by the recommendations in the Wheel & Tyre Bible you will effectively be moving the rim 3mm further away from the suspension components.
The link above can be found in the Yeti Tyre & Rim Guide
Regards,
TP
