octavia tdi wont start
I went to start my octavia tdi this morning the esp off light dident go out and the engen wont fire. when I tried to conect diognostic divice it fail to conect, I have tested all the fuses at the drivers door and by the battry, dose anyone have any sugestions what might be the problem? what shude i try?
Do the ignition lights, etc come on?
Does the starter motor engage and turn?
Do any electrics work?
What "diagnostic device" did you use? Vag-com, or something else?
starter motor working fine other dash lights as normal. im using a elm 327 interface for obd 2, its worked fine till now.
Sounds like an X relay fault, remove the cover around the pedals, look up and you will see the relay plate. I think that it is the relay with 109 written on it, you could try reseating and tapping it. It will have a part number on it if you need to order a replacement.
I had not realised there was a 4x4 1.9tdi mk1. I assume it has fuel :smirk:. Have you tried any other keys? I am wondering if maybe it is an immobiliser type of issue...
thanks for the ideas, ive been thinking imobaliser for a while to .no its not a mark 1 its a 2007 model i dont think they have a 109 relay anymore im not sure what relay has replaced it, got desil in the tank. i tried other keys, unfortunatly dident work, the lift pump dosent work. defenatly seams to me like a relay or fuse or a mouse has been having a chew on the wires.
Doo yu gow ought off yor whey too mispel evry werd?
That took me several goes to figure out what you were saying there :giggle:
