Front wiper not working
My girlfriends 1.2 HTP Fabia (2004) the front wiper has stopped working, the rear wiper will activate from the stalk and its not the wiper motor or fuse as a double tap towards the driver of the wiper stalk activated the front wiper, alll fuses were checked, Is this a relay problem or does the stalk need to be replaced?
is your bonnet closed properly as this causes them not to work, happened to me
Have a look at post #23 on this thread. That guy had the same problem as you and traced it back to the plug on the stalk being loose. If it's not that you could have a faulty stalk.
Thanks I fiddled withthe stalk connection and the front wipers activated? Do i have to take off the steering wheel to access the lateral connection on the steering column because im pretty sure the stalk is not faulty! :'(
Edited by rayman1086
