Remapped Fabia 1.9 TDI PD100 ECU
Ive just removed the remapoped ECU from my car as its going back to standard for the missus (Dont want her smashing it up!) The car is a 2001 Fabia with a ATD PD100 engine, The ECU was remapped by SP Tuning In Hinckley and upped the car to approx 145 BHP and 300NM, I can supply the ECU with the Immobiliser turned off so you can just fit it and it will work or i can suppply you with the Immo Code for you to programme to your car.
I want £150 for it which includes delivery
The ECU is still on the car at the moment and i shall remove it when sold
Forgot to add the ECU part number is 038 906 019 AF
Bump
I WILL GIVE YOU
100 POUNDS
I WILL GIVE YOU
100 POUNDS
No Thanks...
I WILL GIVE YOU
100 POUNDS
No Thanks...
:rofl:
Good luck with the sale, PD100's are quite good fun with a decent map :thumbup:
:rofl:
Yeah i couldnt believe the difference it makes! Can beat most things of the line and transforms the drive through every gear
Bump
Bump, you would amazed at how much more drivable the car is with this ecu!
bump
do you still have the ecu?
cheers ally
Yes ive someone else interested but not sur hoe serious, so its still available at the moment
Guest
