Error Code 01271
I need some advice Guys.
I ran Vag-Com and discovered this new error code as per the title. I've done a few searches here and come across the following comments:-
If the stepper motor has lost its known position then using Vag-Com it can be reset :-
08 Heater/A.C
04 Basic settings
Channel 000 (30 Secs)
001 (30 Secs)
002 (30 Secs) Does that mean you wait 30 seconds?
An old posting (about 1-2 years old) states cost of motor is approx £70-80
I found the part No: 1J2 - 907 - 511F and its location on the left side of the main heater assembly .
Has anyone used that resetting proceedure and did it help?.
Where is the offending motor in the car and is it easy to get to and remove / replace.?. The weird thing is the cooling heating seems to work ok, ie going from cooling to re-cycling and back.
I'll try doing the resetting thing and clearing the code, and see if it comes back first.
Any advice much appreciated.
Peter
The motor is a PITA to replace apparently.
Mine comes up with the fault all the tijme, but still works perfectly, so I'll leave it.
That is an option, after posting I rang Audi main dealer apparently there are 5 in the country at £100.85 including vat
"ouch"
I uplugged mine, set on fresh air only and stopped worrying lol
same as mine not wasting money on that....
Thanks guys :thumbup: ,
Well the laptops on charge so either today or tomorrow I will try the resetting proceedure and see what happens.
I must admit 100 notes seems a little steep for a tiny 12 volt electric motor.
Peter
Edited by Silver Bullet
http://briskoda.net/..._1#entry2037913
It took ages just too umplug it and my hands looked like an emo's afterwards :giggle:
Very funny thread, some of the comments are brill :rofl: ,
Dont you find tho when you are about to tackle something you have never done before, that slight feeling of dread creaps in, will I make it worse or blow something up?.
I cleared the code so tomorrow sounds like ill be upside down after taking a few asprins for my back. Bring back levers and sliders !!!!!!.
