Brake light issues
Hi all
My drivers side brake light stoped working, changed bulb and still not working. Went to play again to sort and now none work! I cant see anything Ive knocked and none of the 3 work now. I presume the switch is easy to change and on brake pedal? (I cant removed trim as at Mrs house without tools).
Any common problems with them?
Sheldon
fuse most likely
Seconded. If it was the switch on one of the diesels, the glowplug light would flash constantly with the engine running.
