Can mpg be changed to L/100km with vag?
Hi,
may be it's a stupid or naive question, but is it possible to make the car display fuel consumption in litres/100km rather than mpg? Don't know whether this is just down to ecu settings or it's the car itself - ecu sw, display etc.
thanks guys
I can do it without a cable, just the MaxiDot settings .... does not work for you?
thanks for your reply, not sure however what is MaxiDot settings. I am new to Octavia, just got a 2nd one recently. It's Octavia I Ambiente. could you give a little more details please.
Googled a bit, seems to me the maxidot thingy is some kind of menu on the center display. I don'thave that though, it's 2002 Octavia, It only has the small display under the rpm gauge.
Yes VCDS can change it :thumbup:
good to "hear" that, any chance you know the steps how to do that?
It may be a bit of trial and error, but on newer cars (10 & 60 plate cars) with maxidot, when you change the cars country to (for example) Australia it defaults to litres/100KM - this can then be changed back in the maxidot (when you have it :giggle: )
For the country change it's under 17-Instruments.
VCDS > Select > 17 - Instruments > Coding - 07
Now wait for the coding chart to pop up and change it to the country setting of your liking.
thanks guys, it worked!
well sort of :) the odometer now shows 'km' and value in kms, but the consumption display still says 'MPG miles' , but shows in l/100km. So perhaps a specific display is required too, but i am ok with what i got. thanks for you help
