alloys measurements
hy guys,
i have a skoda octavia 2010 reg and i want to buy a set of 17'' alloys but i don't know what are the measurements is it 7.5 x 17''
5 Stud
PCD: 5x100 ? i realy don't know
The MKII Octavia is:
5x112 PCD
probably 7.5x17?
The ET will be around 50.
If you go to the Autec alloys website (the English bit of the German .de website is best), there is a configurator which includes all versions of the Octavia. The Scout alloys are 17x7J ET 50 5x112, but there's a whole range of combinations of sizes, widths and offsets.
Les.
You will need 17 x 7J,7.5J or 8J width. (Skoda 'Zenith' alloys are 17x7J or 18x7.5J)
PCD (bolt pattern) is as stated above-5 x 112
Offset (ET) on Skoda wheels is ET50/51, but if you are going with 17 x 7J, anything from ET35-50 would be OK
ET35 means the wheels will sit towards the outside of wheelarches more, (which will look better anyway) 50 will sit pretty much standard.
Therefore, 17 x 7.5J width you'd need to look for an ET of between 40-50, and 17 x 8J would need ET45-55
Presumably an ET of 50-55 would be OK too?
I'd imagine anything up to 5mm protruding from the arches is going to be a problem?
Edit to add: Offset explained
Edited by Lou_O
