Can i change the spec
I order a SE 1.2 dsg with built week of 28, but want to upgrade to a se+ is that possiable?
ou can change the specification on a vehicle on order right up until the build process starts.
However, and here is the big one.
Your build week may change.
As yours isn't until quite a few weeks time you "might" be OK and find you keep the same slot in the queue.
Only your dealer can advise on any delay (if any) you are likely to see because of your change.
I added a couple of options to my car 2 weeks prior to the build date which wasn't a problem the dealer sorted it all for me.
I don't know how easy it is to change the model specification speak with your dealer I'm sure they will be able to help.
A 1.2 SE Plus is not listed on Skoda's website
oh well, looks like i have to stick with my original order,
Just thought since i order rear parking sensor and mdi, it is only another £600 for sat nav, blue tooth and mfsw which was very cheap
Well we all know how inaccurate the Skoda website can be at times so in your position I would ASAP go into the dealer and see if you can change the order to an SE Plus. Nothing ventured nothing gained eh!!!
Ian
