tyre fitting & rear camber adjustment
Hi,
Got 4 tyres to be fitted but also need rear camber adjustred too. Any ideas on good places to get this done ideally in Worcester?
You don't seem to have had much of a response regarding place near to you... I can't either but as a suggestion look for somewhere which charges you for the alignment service, don't bother if they offer to check it free when they do the tyres because the chances are that they will not set the car up properly anyway and then tell you it is "way out" and then charge you to mess about with the settings. Some will also tell you that the camber cannot be adjusted, that is just because they don't know how to do it and you don't want them touching your car anyway.
Hi Sonic.
How about:
http://www.alineyourcar.co.uk/
Not Worcester...but not far..... and I haven't used them personally but have heard good reports....?
