Front door cards are leaking...
Noticed yesterday a puddle of water sitting on the rubber sills either side of the front doors :thumbdown:
I assume its the same as the rears regarding the fix?
Remove Torx in handle once handle is off and remove torx from under the door card?
Price door away and then seal???
The bummer is i will have to drill one of the torx out as the previous owner sheared the head off when messing around with the car....
Is it easy enough to drill out a sheared screw?????
Noticed yesterday a puccle of water sitting on the rubber sills either side of the front doors :thumbdown:
1 torx behind the door handle (wing mirror control on drivers side, blank on passenger side)
3 torx at the bottom of the door card
3 screws under the grab handle / arm rest covers
Fairly easy. Not quite as easy as the rears. I find the hardest bit is always poking a straightened coat hanger (is there a proper tool?) under the grab handle to pop the top covers off.
