fabia 1.4 aub engine code cam sensor
hi
where about is the cam sensor for a 1.4 fabia petrol 2000 reg and how do you replace it
many thanks
hi
many thanks
The inlet camshaft sensor is on the top right (when looking at engine) of the engine next to the coil pack...just undo one bolt and replace sensor..then do bolt up to a low torque value of 8Nm (6lb ft) B)
thanks
thanks
made a mistake I meant the crankshaft speed sensor sorry all I know it is in the gearbox housing any help appreciated
As far as I'm aware (no doubt I will be corrected) there is a roadspeed sensor (electronic speedo transducer) in the gearbox....but only for models without ABS....yours has ABS as it is an AUB engine......what are you looking for and why ???? :wonder:
Edited by fabdavrav
thanks for your help
we have a reading on the computer saying too rich mixture intermittent crankshaft sensor fault
What is the code number for this fault that is comming up....as this is weired!? What computer??? Dealer spec, or ebay???? B)
the hand held diagnostic is a modis snap on the codes are p 0336 and 17573 clear the code and let it idle for 1 hr nothing run it for about 40 miles light comes back on and same codesalso no problem starting no backfire engine turns nice but with a little shake in the idle no exccesive fuel use????
Edited by obe1
Crankshaft sensor is not in the gearbox it's in the back of the engine under the inlet manifold.
Depending on what your actual fault code is with regards to mixture I'd do the basics first, look at changing the fuel filter if it hasn't been done.
So you said, but fault codes arent the be all and end all, needs diagnosis.
sorry but I am totally useless about these things but as in diagnosis so I can ask the mechanic what to ask for
