AIrbag Warning Light
Hi. Today i Was Cleaning my Fabia. And After Cleaning, I Started My Car & The Airbag Warning Light Came On.
Any Ideas
Do you have seat airbags?
If so I suspect you have dislodged one of the plugs under the seat, you will need to locate it, reconnect it, then get someone with VCDS to reset the light.
No I Dont Have Air Bags In My Seats I Only Have The One In My Steering Wheel And Above The Glove Box
Fault code scan required.
Sorry Sill Question. Im New To Skoda's Where Do I Find The Fault Code??????
There are no fault codes visible, you need to find someone with VCDS or a dealer to scan the car for the fault codes, this will tell you which airbag the fault lies with.
There can also be a cable than goes to a sensor in the seats to tell the euc that there is someone in the seat (also for the seatbelt warning light) whilst you have been moving the seat to clean, it has come "free"....just have a look under the seat and make sure that all is ok!! B)
Been to skoda they say it's a battery problem and that I need a new one they quoted 125.00. And they also said that the battery I have I th wrong one?? Does anyone know what the batter specs should be
£125 for a battery??? Feck that ....Right then you need a Bosch "silver" Battery check on their website...these are the best.....takes about 10mins diy fit.! B)
What engine, size, type, year of build, hatch, estate????
Edited by fabdavrav
Does anyone know the size and voltage ect. So I can to PMA And get one.
Volage is 12v...as most cars are (some very rare have 24v)
1.4 16v w reg(2000) hatch
Right then I have a 1.4lt 16v AUB engine hatch in Elegance spec, X reg.....I have a Bosch "silver" 60Ah battery....Bosch have redone the range and on their website they are showing three choices..S3 type code S3 002 (45Ah).......S4 type code S4 002 (52Ah)......S5 type code S5 005 (63Ah). B)
Cool thanks
