MOT Proposed Changes 2012
Just spotted this today at my local garage. Makes interesting reading
Will most probably affect some members here, plus possible push the price of MOT's up !
Karl :thumbup:
Looks like I will be reverting to normal bulbs then put HIDs back in :wonder:
Looks like people with a decat will have to put them back on (and probably remap) before an MOT. That and the HID change will be the main ones that affect Briskoda members.
Good luck checking the power steering level in a Fabia. It's under the battery!
One thing which might be a cause for concern is
"Inappropriate suspension repairs or modifications"
Wonder if that will apply to cars that are on the deck !
Just have to wait and see I suppose, these are proposed changes and are not cast in stone yet.
Doesn't mention DPF but as this is clearly a brief summary could be that this too will be included. Those who have taken it off and remapped may also find they need to refit it.
Forget the gossip and snippets posted all over the internet, what you really want is the manual which the tester will use. There just happens to be a download of the proposed new manual here:
Proposed changes to the MOT Inspection Manual
The link on the page is the sentence as above. Anything marked with a vertical black line is a change over the current manual, to help you notice what has been changed.
We had a discussion of this a while back, before any official documents had been made public, Here.
Not true for all Fabias.
So if HIDs are tested for self levelling, then this surely resolves the HID conversion legality discussion once and for all.
So if you swap out for the MOT, then refit (same for decats etc)how will the police & VOSA deal with this at the roadside?
Ahh more paperwork, more time, more money! thanks eu!
**UPDATE**
This was seen on SCN (In this Thread here) and was originally posted on an unknown Forum Edition38.com forum Here http://www.edition38.com/forums/index.php?showtopic=381364
Know Your Legislation
I am creating this post not for scaremongering, but to educate on current and proposed legislation with regards to modified vehicles. Most of this legislation has been in place for years, but many people either have never heard of it or have no understanding of it. Recently the organisations involved in policing these regulations have begun to enforce them more thoroughly.
Forthcoming MOT regulations
First the good news. After consultation with a number of agencies and organisations the proposed changes to the MOT system to be implemented in January 2012 have been amended. Therefore:
• There will NOT be a total ban on the use/sale of aftermarket HID kits, which was a major part of the proposal. The current MOT rules state
High Intensity Discharge (HID) and LED dipped beam headlamps (whether original fitment or after-market) must be fitted with a headlamp washing system (a wiper is not required) and be self levelling. This may be achieved by the use of either headlamp or suspension levelling systems. However, some high performance vehicles fitted with HID headlamps that have limited luggage space and stiff suspension do not require a self-levelling system.
Reason for failure: A mandatory headlamp levelling or cleaning device missing, inoperative or otherwise obviously defective
• There will not be a ban on “illegal†engine tuning. Frankly there was no way a visual inspection could identify an aftermarket chip or re-map anyway, and this proposal was met with universal contempt by MOT testers. The only reference in the new manual to this is that modified cars must meet the correct emissions level for the year of engine.
Changes to the MOT that could affect lowered cars
These are the changes that have been implemented.
• Check that there is enough clearance of the axle or suspension with the bump stop or chassis
• Check that there is sufficient clearance from body to wheels
Reason for failure:
Inadequate Clearance of the axle or suspension with the bump stop or chassis.
Inadequate clearance between body and wheels.
Deliberate modification which significantly reduces the original strength, excessive corrosion, severe distortion, a fracture or an inadequate repair of a load bearing member or its supporting structure or supporting panelling within 30cm of any sub-frame, spring or a suspension component mounting, that is, within a ‘prescribed area
The key word in the first definitions is ‘inadequate’. This leaves it to the discretion of the MOT tester on what classes as inadequate. It’s not a massive problem, as I’d imagine most lowered car owners will have a friendly MOT tester that they use anyway. If not it might be time to find one. The 2nd part is interesting, for instance a chassis C notch could be seen as reducing the strength of the supporting structure for the front subframe.
That’s about all we can find that affects modified cars in the new manual, so much better than first thought.
Vehicle Registration Laws
There are 2 different organisations involved in this process.
The DVLA maintain the database that contains all the drivers and all the vehicles in the UK.
VOSA regulate the MOT test and perform roadside checks to improve road safety.
The “8 points†Registration System
To put this system into context, people must understand that you never own the registration document for a vehicle. It is purely on loan and they can remove the right to registration if a problem arises.
The “8 points†system is how they determine whether a car should retain its original registration. First they assign each major part of the car a set point score like this.
• chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
• suspension = 2 points
• axles = 2 points
• transmission = 2 points
• steering assembly = 2 points
• engine = 1 point
To retain it’s original registration, the vehicle must score 8 or more points from this list. However this must always include the 5 points for the original UNMODIFIED monocoque shell/chassis. This doesn’t sound too bad, but say for a Mk2 Golf with a VR6 or 1.8T conversion, aftermarket suspension and a disk brake axle on the rear you’d have 7 points. The problem with this system is that if/when you take your car to be DVLA inspected it is down to the tester’s discretion on whether he allocates the points or not. The DVLA actually define each part as "the original part that the vehicle left the factory with". Obviously this is impossible to implement, as all the parts listed have at least a fair chance of being replaced throughout the life of a vehicle, not for modification but for warranty claims and servicing. For instance it's fair to say that if you go to a test with performance suspension parts fitted rather than OEM standard replacements you will lose those points.
What constitutes an Unmodified Monocoque?
Firstly it’s probably best to explain what a monocoque shell constitutes. From the DVLA definition:
“What constitutes a monocoque is that of how an OEM manufacturer would view it. The chassis or `cage` assembly and all components that form it, less any cosmetic panels or infills that make no structural consideration to the monocoque or its component parts.â€
That bit basically.
What this means
Your car WON’T need an IVA if you:
• Roll/Flare the wheel arches
• Fit different cosmetic panels (i.e. front end conversion, US/JDM body panels)
• Fit a roll cage (aslong as the existing shell isn’t cut to fit it – holes through bulkhead to fit bracing bars to strut tops a no-no for instance)
• Fit/remove a sunroof aslong as you don’t chop any strengthening members.
• Convert a car to a van – as you are adding to the existing structure.
Your car WILL need an IVA if you:
• C notch the chassis legs for driveshaft clearance
• Raise the strut tops
• Modify the floor or bulkhead
• Chop the roof off/convert to a pickup
• Cut the outer arch lip for tyre clearance/to fit a wide arch kit, as this is classed as a structural area
• Modify any part of the monocoque
From reading the DVLA rules as long as you don’t add to the width or length of the vehicle it is fine to add strength to the monocoque. Therefore if you weld plate over the existing chassis legs and fill the holes in the bulkhead to smooth an engine bay you should be fine. However if you cut the bulkhead out and weld in a complete flat sheet section, or chop the chassis legs out and refabricate in box section you will be liable to IVA the vehicle.
How is this enforced?
These seem to be the main ways that people are caught in contravention of the rules:
• Changing body type on V5 – If you send off the V5 with the body type changed it will automatically flag up the car for an inspection.
• VOSA/Police Spot Check – If you are pulled into a VOSA/Police checkpoint they can pass information onto the DVLA if the vehicle is not what it says on the log book.
• Flagging up modified vehicles for inspection at shows and from magazine articles - keep your registration plates/chassis number (if visible to outside i.e. in windscreen) hidden if possible to make it more difficult.
There is a rumour flying around that they are going to give the MOT tester a “modified vehicle†button which he has to check if a modified vehicle goes for an MOT. If this is checked it will flag the vehicle up for inspection. However there is no evidence to say this is in the pipeline.
What happens if my car is flagged for inspection?
If your car is flagged for inspection you will be summoned to the nearest DVLA office. A trained inspector will then go over the car allocating points based on the above values. If the car passes the inspection the vehicle will retain its registration certificate. If the car doesn’t pass the inspection it’s registration certificate will be revoked, meaning that the car cannot be used on the road.
To re-register the vehicle it must pass through an IVA test.
The IVA test
The IVA test is a stringent inspection to register amateur built/radically altered vehicles. It was implemented as the old SVA test had no class for inspecting radically altered vehicles.
The test is too stringent to go into in a forum post. There is a PDF of the manual here
http://mcelroymotorsport.co.uk/Docum...may%202009.pdf
Most cars post mid 70s are type approved, and therefore in standard form should easily pass an IVA test. However in modified form it may be more difficult. There is definitely no way that a car running poke, stretched tyres or scrub line interference will pass. The best thing would be to print a copy of the manual off, buy a radius tool off ebay and go through each pointer making sure it will pass. It's laborious, but on the plus side it will give you an insight into how much though goes into designing a car to pass crash safety tests.
Costs
The costs of an IVA test are fairly high, around £450 (no vat), then £99 (no vat) for a re-test if you fail.
Chances of getting caught
Put simply, there is no way of knowing. There are thousands of cars that are still using their original registration number when they should be having an IVA test. You could drive around for 10 years and never get a whiff of an inspection, but on the other hand you could apply to swap onto a private plate, or an engine swap, and get flagged for inspection. It really is pot luck, but as time goes on there is a good chance they’ll find new ways to catch people out.
There is a current proposal that the DVLA local offices will be closed and their powers given to the Police/VOSA. Apart from the fact that it will mean the people doing the inspections will be more clued up on modified vehicles, I feel it could also give more ammunition to the police to clamp down on modified cars that whilst not necessarily illegal in basic terms (MOT, tax, insurance present) fall foul of the regulations.
Please feel free to ask questions, I will do my best to answer them.
Matthew Smith
http://www.the-ace.org.uk/
The Association of Car Enthusiasts aims to report on and fight against forthcoming vehicle legislation that has a damaging effect on the modified car "hobby".
Edited by Jim H
Blimey, looking at one of the unamended sections in the manual on suspension pin testing, wear limit is 2mm on a 12mm pin (16% !!!). You couldn't be any more generous than that, viz:-
If a lateral load was applied at 90 degrees to the direction of travel causing full deflection of the pin by 2mm, that would represent approximately 17 degrees of deflection at the centre of the pin (1.78mm at the circumference). If the steering and suspension geometry translated this degree-for-degree into a track change, you could be in trouble.
Using the one-in-60 rule for every 60 foot travelled foward and with a one degree deflection, if the deflection always favoured one side, theoretically you would arrive at the 60 foot marker displaced to the side by one foot. If the deflection angle is consistently maintained at 17 degrees, after 60 foot of travel, you'd be 17 foot to the side of where you wanted the vehicle to be i.e. in a ditch or on the opposite carriageway. At 70 MPH you travel 102.67 feet a second, with a 17 degree deflection you'd be well off the road in .58 of a second.
So basically, with this degree of wear, its only inconsistency in road surfaces, and contra-acting/compensating wear in other suspension/steering components and unconscious adjustment by the driver that would keep the vehicle safe .
Nick
Edited by Clunkclick
It just goes to show what a low standard the MOT test is. One of the first things that I was told when attending a training course was, that if you want to become a tester, you will have to lower your standards, a good illustration of this is the section on brake discs in the manual.
Be glad you don't live in Japan, the MOT there (shaken) can cost a huge amount of dosh.
I see that a failure of the ESP system will result in a failure - maybe then the VAG group will have to give in and change all the Teves MK60 ABS unit that all fail under a recall????? If it should fail an MOT it is a safety issue - therefore surely it becomes recall item?
