Brembo Clerance
What the minimum clearer you would/need to have between the calipers and the wheel spokes?? Had mine fitted today and its bloody close! Do you need to leave a gap for heat expansion etc??
thanks
Nope, if you can fit a fag paper in cold, you can do it hot, a bridge expands like an inch in the heights of summer from the lows of winter. calipers... wouldnt worry.
Thanks, 1mm clearance will do me then
What wheels and spacers are you running?
Leon fr+ wheels, (17" version of LCR Wheels) and I think it was either a 3mm or 5mm spacer I had to fit
pics please B) - sounds good Mr st3f4n, glad you didn't have to sell in the end...
Me too mate, I'll get some pics up tomorrow hopefully after its had a wash, need darker wheels next to set the green calipers off.
Mine is under 1mm and it's fine
Some pics
There amazing, slowly bedded them in but did a few hard brakes today and almost went through the screen, The brake pedal is 10x's harder aswell
I did notice this tho,
Its a scuff from a spoke :/ Getting some 7mm spacer asap... You can see how close they are
The LCR wheels were designed to fit those calipers under ;)
Those although they are Brembos they aren't the LCR ones, they fit with no spacers and the 17" wheels.
LCR ones are flat on the edge, quite different to these cheeps being flogged on eBay as LCR ones.
To st3f4n
Think you need to change the monster truck tires while your at it
To st3f4n
Yeah, 225/45 17 are a way out.
Some real lcr ones with wheels that dont need spaced :o
Huge +1...
The others look rubbish, I hate it when people consider them the same thing!
I didnt think that brembo`s even went under 17" wheels on the seats anyway
Matt
Yeah, the Leon R didn't originally have 18" wheels but had the Brembos.
Had the GT Brembo kit on my Fabia and the 17" LCR alloys (before the FR+ was released)
@ st3f4n, Are them brakes one of them kits off ebay ?
Huge +1...
Don't you have the other brembos?
:wonder:
:wonder:
No, mine are LCR ones.
I parked next to my mates LCR and they look identical and the the DS-2500's I ordered were for a LCR too. I've seen the eBay Brembo's with the 2 lines down the side of them and they look really weird IMO.
Caliper looks a little different to the LCR one, can't see the Allen key bolts holding the two halves of the caliper together, mono block calipers?
No, there the same as mine. I agree they look identical to LCR ones but ours are bolted from the rear for some reason.
