vRS ARB
Can someone confirm the diameter, Please?
If your looking for the size needed to polybush the front? mine is an 06 vrs was 19mm.
Cheers!
A bit of deduction has it @ 20mm OD, Replacement bushes and droplinks ordered!
Keeping them rubber!
Hopefully this should cure the sloppiness on cornering!
They are 20mm (might even be 21mm) but Powerflex don't make anything larger than 19mm so you have to use them.
