Clutch peddle sticking
My clutch pedal is starting to stick when depressed down, I can lift it by putting my toe under it and lifting it back up what could have gone wrong
Edited by skippy41
Could it be the clutch master cylinder that needs replacing, if so how much and how long to change it
Got the new master cylinder, cannot get the car to the garage wont come out of gear so waiting on the AA
Edited by skippy41
have you tried "pumping" it say 20 plus times, (depress the pedal, pull it back with your foot and then continue doing this 20 plus times, maybe more) - sometimes there is air in system and pumping it many times can bring the pressure back
not a permanent solution, (if it works) - but should get you going
Edited by BillN_33
Tried pumping it did not work.
Got the new one fitted £70 for the part £70 for fitting.
Just out of interest where is the fluid reservoir for it????
