wheels
hi all,could anybody tell me what wheels fit a felicia,i've just got the standard 13 inch steels but would like to go up a size,nothing crazy and keeping to steels as i use the car for deliveries every day,someone told me that vauxhall wheels fit is this true?
Alot of wheels will fit aslong as you ge the correct fitments which are PCD 4x100 Offset : 35 to 45 Bore : 57.1, you probably could have wider range of offsets depending on the width of the wheels etc you can also get wheels with a bigger bore just make sure you get some spigot rings.
As for vauhall wheels im not sure they will fit because the bore is 56.6 on the corsa and astra so i presume all of them are.
But wheels from 4 studded VW's should fit golf,polo,passat....
As for actuall size you probably go from 13" to 17" you jut have to make sure you get the rolling radius roughly the same give or take a few mm.
I like to use this site for that:
http://www.alloywheels.com/tyrecalc.asp
I think all the info i have supplied is acurate, if not someeone feel free to correct me.
17"'s on a Felly!!! really??? must be a 35 sidewall profile to fit like a 215/35/17, wouldn't that make it too wide for the front??
i quite like the 15" mk2 golf GTI wheels and they fit on i think (4 stud) and can be picked up with healthy tyres on for like £80-£100
you may as well, deliveries or not!
Yeah 17" wheels do fit i had them on mine for a while, but because mines lowered it did catch at the front occasionally so they would be fine with standard springs.
Pic of mine when it had 17s on:
http://i229.photobucket.com/albums/ee98/nu99et/phone/86bbccf6-64c5-4a29-aa5d-11b5e39fe67c.jpg
that was with 205/40/17 tyres, the 215/35/17 are near enuough the same rolling radius as my original 185/60/14 but probs too wide or even if they fit i guess there would be way too much rubber!
they make a 185/35/17 tyre which would fit easy but it would just be silly.
Cheepy steelies are off a mini one. I got a set with just about legal tyres off ebay for £40. They need the spigot hole reaming out a bit. I did it with a grindstone mounted in a router. 65 profile tyre rub a bit (my trucks lowered) I put some pics on here somwhere, god knows where tho!
Oh they are 15 inch by the way.
Edited by jonny a
how low did u lower it
35mm all round...
