To Methanol owners...
model shops....
its injected into engine when a certain boost pressure is reached.
  • Replies 51
  • Views 5k
  • Just to emphasise the above. Methanol is rated IIS in my lab (This is the 2nd most serious, a I will likely kill you or at least cause irreversible damage i.e. cancer). The S means it is a skin sensit
Yeah, injected into the post intercooler pipework in a fine mist form, so it effectively becomes "air" during the combustion process.
I bought a 230 litre barrel of meth from a place I found online! :D Was the cheapest way to get it in bulk and not surprisingly the barrel is still quite full two years later. :D
Any links to a suitable kit? Is it safe to run it all of the tine?
Devilsown, search it in google
Pah if you think pouring a couple of litres of meth into a funnel is dangerous you need to get out of the office and work in some factories... Im surprised im not posting this from beyond the grave
Oh sorry I'll go play with the oxycetaline bottles if you like then wash it down with the plasma cutter and finish up with a shot of 2pac spray paint with only a filter mask.
This forum ain't half getting bitchy
Not my area this - I though we were talking washer bottles here to start with! :o
I'm someone who used to rub meths rather than Rubbing Alcohol* on my feet to harden them up & frequently spend time up a hill in a small tent cooking on a stove that burns the stuff & I am surprised at the cautions being advocated for infrequent use under discussion. I may be doomed I guess.
I do agree with you Sy however - but seen worse recently on other threads.
*Rubbing Alcohol aka Surgical Spirit is 70% Isopropyl. Even that "May be harmful by inhalation, ingestion or skin absorption. May act as an irritant. UK OES Long-term 980 mg/m3." :o
i thought we were friends :beer:
They don't have skoda on their site, couldn't find it under vw either
It's harmless Tongue in cheek banter which I learnt the hard way lol
Do people leave their meth injection switched on all the time?
I'd just give them a call. There are enough 1.9tdi VW engines using it.
always wondering this?
im in northern ireland so not sure who would fit it etc or are the kits easily fitted?
Its a pretty straight forward system
All it is is a water tank, pump and mist nozzle
It works off a boost pressure switch so only comes on when a certain boost pressure is acheived so not on all the time anyways
You'd be better fitting a fmic tbh
Some setups work so it starts injecting at say 1 bar of boost. Mine starts injecting at about 2/3 of a bar, and it is progressive up to 2 bar. This way it is injecting more when the car needs it, i.e full acceleration, and is only putting a little bit on medium acceleration. :)
Cheers Jason and Jase.
Yes, mine is the progressive system.
I tend to leave mine switched off. Looks like there is no need.
Thinking about it I only switched it on to test the car at Jabbasport and once afterwards.
Even when I made the two videos it was off. :blush:
Still, on the bright side... more power to play with. :devil:
virtually the same job then, seatsport intercooler would cost more tho im guessing having looked at a few kits.
does the map need to be tweaked for the kit for it to start at a certain boost or is this automatic?
not much more, the benefits of a fmic compared to an smic with water meth would be night and day...
fmic first, then water meth if you like...
there would be a bit of wiring with a meth kit, boost switch and relay, beyond me like :rofl:
Thankyou :)
Does anyone use water + Methanol as their screen wash? I met a guy with a TT who had a Methanol kit and he said he uses it as his screen wash all the time as it's cheaper than screenwash etc...
Will it damage anything?
Some kits use the washer bottle under the bonnet instead of a seperate filler bottle in the boot.
Acts as screenwash and the meth reserve in one.
I assume you mean that set up?
Yes, that's how mine is setup
Mines a 2.5gallon tank in the rear. I find my screen wash bottle is too small for even the windows in winter etc. Couldn't be arsed filling it up every time the low level light came on
Yeah same but I just won't use it anymore and Meth is gunna be turned on and off so won't use much I doubt
Will it harm the paint etc?
Ahh yours is the on off one. Mine is always on but it if I just mooch/Sunday drive it doesn't inject at all. As the pressure are set high
