Felicia 1.3 engine problems
Car: Skoda Felicia 1997 1.3 Mpi
Problems:
After 10 km driving,engine starts cuting out when going harder into a corner(especialy left) and when driving away
from a stop.Into a corner, then after 2 sec engine cuts out for 3 sec, pulls a little, and then goes on.Or I stop
want to drive away, the moments it starts pulling, engine cuts out for a sec or two.
The next 5 km it gets rapidly worse to the moment I can't drive 5 m.If I turn the car off, make contact, wait a little , start car, I drive normaly for 500m.Or wait 15 min and drive without problems couple of km's.
Solutions tried:
Fuel system overhault(New filter,fuelpump cleaned,tank cleaned,hose check -was unbelivable dirty)
Ingnition system check(New HAL sensor,new sparkplugs, cable check)
Throttle body (replacement throttle body, new air flow sensor, cable and connector check)
I was today at the skoda servis, and the electrician should have calibrated the new throttle body.He also found 8 faults/errors in the memory he seccesfuly erased.
The car won't run. So I try here before I start searching for a replacmment doner felicia.
The car is in mint condition and from my grandfather with 56k km.I really wana make it run.
Thanks for any help.
Problems:
Solutions tried:
were the faults in the memory fixed before the codes were erased.....do you know what the codes were ?...
It was more of a guy that had a hard time saying good morning, and he was typing so fast you couldn't see nothing.
He was saying something about the labda, but I saw he had a problem erasing "shortcircuit on minuspole" error, went around the car, disconnected tester and said I should replace the air flow sensor, wich I have 3 used ones and doubt
not 1 is ok, but he insisted on new one.
How could I somehow find out if I am without spark or fuel injection the moment it is the worst?
I don't know anymore....
hi there i could be your imobilser does it crank over and when you put ignison on does is there a sound like fuel pump working you can check code with vag com
