ABS PUMP FAILURE
HELLO chaps,
got problem with my skoda octavia 2005 tdi, ive lost power steering and other controllers are reporting abs data bus missing. I have gone through the fuses and relays and no joy. I have also checked for power supply to the abs unit and power is there.....two positive power supplyes and earth. So in my opinion i think i have problem with non working abs computer? The part number of my abs ecu is 1K0 614 117H BEF, is there is a replacement part number i could use instead??? Perhaps from audi A3, Golf V, or SEAT Leon?
here is the log
Monday,20,June,2011,21:17:54:62365
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBBS21Z452064713 Mileage: 117960km/73296miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 K HW: 028 101 223 7
Component: R4 1,9L EDC G000SG 7002
Revision: 12345678 Serial number: SKZ7Z0E2833403
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 2B5EEC49F395
4 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Bin. Bits: 00000000
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 107.4 Nm
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00101100
Temperature: 27.9°C
(no units): 240.0
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00101100
Temperature: 27.9°C
Duty Cycle: 9.6 %
Readiness: 1 2 0 0 1
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0304
Shop #: WSC 00000 000 00000
VCID: 3B7EDC0903F5
2 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
01316 - ABS Control Module
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000003001742
Coding: 418A0F020004140000110D000000000000087F075C
VCID: 3A70D90D0CCF
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Component: Fehler Lin-Slave 02
3 Faults Found:
02071 - Local Databus
004 - No Signal/Communication
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit
02401 - Terminal 75x
006 - Short to Plus
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 K HW: 1K0 909 605 K
Component: 04 AIRBAG VW8 024 0700
Revision: 07024000 Serial number: 00378D05ZJ04
Coding: 0012340
VCID: 346CF7352EAB
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000042
VCID: 356ACA3125D1
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 910 D
Component: KOMBIINSTRUMENT VD1 3562
Coding: 0007401
VCID: 346CF7352EAB
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001051260B16
Coding: 3D3F0740071303
VCID: 29521641F969
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 182
Mileage: 117963 km
Time Indication: 0
Date: 2000.00.00
Time: 00:04:37
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3562
VCID: 346CF7352EAB
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0166
Coding: 0000118
VCID: F4ECB735EE2B
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 3162FE21D1B9
3 Faults Found:
00625 - Vehicle Speed Signal
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 7920 km
Temperature: 20.0°C
Voltage: 12.50 V
Voltage: 12.40 V
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 7920 km
Temperature: 20.0°C
Voltage: 12.50 V
Voltage: 12.40 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 81F802007F2D8505485F861004
VCID: 7BFE1C094375
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
2 Faults Found:
01134 - Alarm Horn (H12)
01312 - Powertrain Data Bus
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000118
VCID: F5EA8A31E551
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 A HW: 01. 01. 03
Component: Radio FO3 0008
Coding: 0000402
VCID: 2C5CEF55F69B
1 Fault Found:
00880 - Connection to Speaker Rear Left
006 - Short to Plus
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0219
Coding: 0000048
VCID: 2F66F859C78D
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 3064FB25DAB3
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
VCID: 3D7AD2111DE1
End ---------------------------------------------------------------------
any ideas
hello there, thanks for your input!
i have cleared all other fault codes and the ones that come back are the ones related to ABS. I have checked power supply to ABS unit and i do get two positive supplies (cannot remmember the pin numbers now)and one earth so in my opinion i belive there is demaged abs unit?
what do you think?
Maybe put up the errors that are left on there now, might help
ok, ill do that in the morning
thanks for your help
