oil pan
hi there guys..need some help pls..does anyone know how to properly remove the oil pan?so i could get to the oil pick up pipe,and do i have to put some oil in the new oil filter?any help would be much appreciated thanks alot in advance..
http://briskoda.net/forums/topic/191103-vrs-pick-up-pipesuction-pipe-replacement/
try that, easy enough job apart from 2 bolts on the sump at gearbox end with tricky accessemoticon-0148-yes.gif
