vrs Front brake disc dimensions
Hi guys, changing front discs are these the correct dimensions
vrs 1.8t
Vented - Mountings 5
Disc diameter 312.0mm
Disk thickness 25.0mm
Overall height 49.7mm
Centre diameter 65.0mm
Minimum thickness 22.0mm
Also i can have just plain dics or grooved,drilled, dimpled etc for no extra charge, is it worth doing or keep standard discs?
thanks in advance
Damien
Damien,
They look right to me, if I remember correctly. I know they are 312x25 for sure.
As for the grooved/drilled etc - to have the properly done and heat treated so they are less likley to fail they can be costly please see here:
http://www.awesome-gti.co.uk/product.php?xProd=11709&xSec=9208 (Select 312mm at the bottom, 256mm rears if they are of any intrest to you)
They also offer F2000 discs, same price but just grooved!
Also some very good pads to suit!
http://www.awesome-gti.co.uk/product.php?xProd=11715&xSec=9917
Mike
Dont botherwith anything drilled or grooved, dont need them! cause vibration and dont do a geat deal
Stick with plain discs and if you want uprated pads, but stay away from EBC!!!!
Then you cant go far wrong
I use Pagid stuff from eurocar parts on both the standdard 312mm set up and the porsche brakes i have now and they are really really good
Pagid from Euro is a cheaper compound than Pagid supplies OE, we get more comebacks with squeel and the bite isn't as good. The stock 312 with genuine (discs are fully anti-corrosion coated) discs/pads takes some beating, if you want an almost over sharp pedal going to DS2500/GreenStuff or similar pads will up the friction but inrease either squeel or brake dust. OE cost a few quid and were really the premium in terms of reaching the best balance between braking, dust, cold response and squeal.
Greg.
